HI,
I'm searching for an good way to edit simple movies from my ZX5.
I've tried TMPGE Mastering Works 5 and SmartCutter with the mpeg4 source files and was a bit scared about the result.
Is there any solution that has something like "smart render" and allows to add Music and audio-transitions?
what Editor would you prefer for mpeg4 files? (vegas,pinnacle,magix,..)
Many thanks for advice
I own a kodac zx5.....if you want lossless cutting on keyframes, then MpegStreamClip or AviDemux will fill your needs. If you want advanced editing then Vegas is a good choice and AviUtl is a good "free" editor. Either one will work without breaking a sweat.
The zx5 is pretty light-weight as editing goes........Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Kodak Playsport ZX5 questions
By mprzybylski in forum Capturing and VCRReplies: 6Last Post: 15th Jun 2013, 12:50 -
Solution: "bad playback" when FFMPEG .TS to MKV/MP4
By VideoGuruDude in forum Video ConversionReplies: 0Last Post: 23rd Feb 2013, 13:36 -
Kodak PlaySport zx5 problems
By JaneHarris in forum Newbie / General discussionsReplies: 4Last Post: 10th Nov 2012, 12:04 -
One deviant "Quicktime file". Is there a solution?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2011, 18:54 -
A "why did they do that?" and question about "retro-editing" (if you will)
By takearushfan in forum EditingReplies: 10Last Post: 31st Jan 2010, 22:02
